[petsc-dev] sm_70
    Barry Smith
    bsmith at petsc.dev
    Sun Sep 27 15:13:39 CDT 2020
https://gitlab.com/petsc/petsc/-/merge_requests/3252 <https://gitlab.com/petsc/petsc/-/merge_requests/3252>
> On Sep 27, 2020, at 11:55 AM, Zhang, Hong <hongzhang at anl.gov> wrote:
>> On Sep 25, 2020, at 8:09 PM, Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> wrote:
>>   Configure by default should find out the available GPU and build for that sm_*  it should not require the user to set this (how the heck is the user going to know what to set?)  If I remember correctly there is a utility available that gives this information.
>>   For generic builds like in package distributions I don't know how it should work, ideally all the possibilities would be available in the library and at run time the correct one will be utilized.
> For package distribution we should add as many possibilities as possible. To have maximum compatibility on CUDA 11, we can add
> -gencode=arch=compute_52,code=sm_52 \
> -gencode=arch=compute_60,code=sm_60 \
> -gencode=arch=compute_61,code=sm_61 \
> -gencode=arch=compute_70,code=sm_70 \
> -gencode=arch=compute_75,code=sm_75
> The downside is longer compilation time and fatter binary.
> Hong (Mr.)
>>   Barry
>>> On Sep 25, 2020, at 5:49 PM, Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> wrote:
>>>    '--CUDAFLAGS=-arch=sm_70',
>>> seems to fix this.
>>> On Fri, Sep 25, 2020 at 6:31 PM Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> wrote:
>>> I see kokkos and hyper have a sm_70 flag, but I don't see one for PETSc.
>>> It looks like you have to specify this to get modern atomics to work in Cuda. I get:
>>> /ccs/home/adams/petsc/include/petscaijdevice.h(99): error: no instance of overloaded function "atomicAdd" matches the argument list
>>>             argument types are: (double *, double)
>>> I tried using a Kokkos configuration, thinking I could get these sm_70 flags, but that did not work.
>>> Any ideas?
>>> Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200927/3a84e85a/attachment.html>
