[petsc-dev] sm_70
    Jacob Faibussowitsch
    jacob.fai at gmail.com
    Fri Sep 25 20:36:13 CDT 2020
>  Configure by default should find out the available GPU and build for that sm_*  it should not require the user to set this (how the heck is the user going to know what to set?)  If I remember correctly there is a utility available that gives this information.
For CUDA I believe the tool is nvidia-smi. Should make sure this automatic detection works when configuring —with-batch though since login nodes might have different arch than compute.
Best regards,
(Jacob Fai - booss - oh - vitch)
Cell: (312) 694-3391
>   For generic builds like in package distributions I don't know how it should work, ideally all the possibilities would be available in the library and at run time the correct one will be utilized.
>   Barry
>> On Sep 25, 2020, at 5:49 PM, Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> wrote:
>>    '--CUDAFLAGS=-arch=sm_70',
>> seems to fix this.
>> On Fri, Sep 25, 2020 at 6:31 PM Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> wrote:
>> I see kokkos and hyper have a sm_70 flag, but I don't see one for PETSc.
>> It looks like you have to specify this to get modern atomics to work in Cuda. I get:
>> /ccs/home/adams/petsc/include/petscaijdevice.h(99): error: no instance of overloaded function "atomicAdd" matches the argument list
>>             argument types are: (double *, double)
>> I tried using a Kokkos configuration, thinking I could get these sm_70 flags, but that did not work.
>> Any ideas?
>> Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200925/5bb8d859/attachment-0001.html>
