[petsc-dev] sm_70
    Barry Smith
    bsmith at petsc.dev
    Fri Sep 25 20:09:30 CDT 2020
  Configure by default should find out the available GPU and build for that sm_*  it should not require the user to set this (how the heck is the user going to know what to set?)  If I remember correctly there is a utility available that gives this information.
  For generic builds like in package distributions I don't know how it should work, ideally all the possibilities would be available in the library and at run time the correct one will be utilized.
  Barry
> On Sep 25, 2020, at 5:49 PM, Mark Adams <mfadams at lbl.gov> wrote:
>    '--CUDAFLAGS=-arch=sm_70',
> seems to fix this.
> On Fri, Sep 25, 2020 at 6:31 PM Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> wrote:
> I see kokkos and hyper have a sm_70 flag, but I don't see one for PETSc.
> It looks like you have to specify this to get modern atomics to work in Cuda. I get:
> /ccs/home/adams/petsc/include/petscaijdevice.h(99): error: no instance of overloaded function "atomicAdd" matches the argument list
>             argument types are: (double *, double)
> I tried using a Kokkos configuration, thinking I could get these sm_70 flags, but that did not work.
> Any ideas?
> Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200925/fbdd3274/attachment.html>
