[petsc-dev] Kokkos initialize
Mark Adams
mfadams at lbl.gov
Fri Oct 16 14:26:16 CDT 2020
I don't have a problem with that.
On Fri, Oct 16, 2020 at 11:16 AM Junchao Zhang <junchao.zhang at gmail.com>
wrote:
> Let me have a look. cupminit.inc is a template for CUDA and HIP. It is OK
> if you see some symbols twice.
> --Junchao Zhang
> On Fri, Oct 16, 2020 at 8:22 AM Mark Adams <mfadams at lbl.gov> wrote:
>> Junchao, I see this in cupminit.inc (twice)
>> #if defined(PETSC_HAVE_KOKKOS)
>> ierr = PetscKokkosInitialize_Private();CHKERRQ(ierr);
>> PetscBeganKokkos = PETSC_TRUE;
>> #endif
>> And I see
>> ierr = PetscKokkosInitializeCheck();CHKERRQ(ierr);
>> In the Kokkos operators.
>> Are these redundant?
>> On Thu, Oct 15, 2020 at 10:44 PM Mark Adams <mfadams at lbl.gov> wrote:
>>> Si it seems like these two calls in cupminit.inc are
>>> inconsistent with lazy:
>>> 22:41 adams/gamg-reduce-opt-cuda *= ~/petsc$ git grep PetscBeganKokkos
>>> src/sys/objects/cupminit.inc: PetscBeganKokkos = PETSC_TRUE;
>>> I can do an MR to remove these if that is the case.
>>> Mark
>>> On Thu, Oct 15, 2020 at 8:34 PM Barry Smith <bsmith at petsc.dev> wrote:
>>>> I thought the plan was that Kokkos also had a lazy initialization but
>>>> perhaps it does not and needs to be fixed.
>>>> Barry
>>>> > On Oct 15, 2020, at 6:49 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>>> > I am running a on SUMMIt with a Kokkos cuda configuration and while
>>>> debugging with ddt I noticed that it spent a long time in KokkosInit, but I
>>>> was not using Kokkos. KokkosInit was call in PETSc's GPU init, which seems
>>>> logical enough, but it would be better if it is not called if you are not
>>>> using Kokkos.
>>>> > I recall seeing places where Kokkos is checked when calling a Kokkos
>>>> method (ie, lazy initialization). Do we have policy on whether we are being
>>>> lazy with KokkosInit or not?
>>>> > Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20201016/59ee447a/attachment.html>
