[petsc-dev] Kokkos initialize
Junchao Zhang junchao.zhang at gmail.com
Fri Oct 16 10:16:19 CDT 2020
Let me have a look.  cupminit.inc is a template for CUDA and HIP. It is OK
if you see some symbols twice.
--Junchao Zhang
On Fri, Oct 16, 2020 at 8:22 AM Mark Adams <mfadams at lbl.gov> wrote:
> Junchao, I see this in cupminit.inc (twice)
> #if defined(PETSC_HAVE_KOKKOS)
>     ierr = PetscKokkosInitialize_Private();CHKERRQ(ierr);
>     PetscBeganKokkos = PETSC_TRUE;
> #endif
> And I see
> ierr = PetscKokkosInitializeCheck();CHKERRQ(ierr);
> In the Kokkos operators.
> Are these redundant?
> On Thu, Oct 15, 2020 at 10:44 PM Mark Adams <mfadams at lbl.gov> wrote:
>> Si it seems like these two calls in cupminit.inc are
>> inconsistent with lazy:
>> 22:41 adams/gamg-reduce-opt-cuda *= ~/petsc$ git grep PetscBeganKokkos
>> src/sys/objects/cupminit.inc:    PetscBeganKokkos = PETSC_TRUE;
>> I can do an MR to remove these if that is the case.
>> Mark
>> On Thu, Oct 15, 2020 at 8:34 PM Barry Smith <bsmith at petsc.dev> wrote:
>>>   I thought the plan was that Kokkos also had a lazy initialization but
>>> perhaps it does not and needs to be fixed.
>>>   Barry
>>> > On Oct 15, 2020, at 6:49 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>> > I am running a on SUMMIt with a Kokkos cuda configuration and while
>>> debugging with ddt I noticed that it spent a long time in KokkosInit, but I
>>> was not using Kokkos. KokkosInit was call in PETSc's GPU init, which seems
>>> logical enough, but it would be better if it is not called if you are not
>>> using Kokkos.
>>> > I recall seeing places where Kokkos is checked when calling a Kokkos
>>> method (ie, lazy initialization). Do we have policy on whether we are being
>>> lazy with KokkosInit or not?
>>> > Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20201016/a697cdf6/attachment-0001.html>
