[petsc-dev] PETSc always recompiles mpi4py petsc4py even when it does not have too
Sun Oct 11 08:30:54 CDT 2020
On Sun, Oct 11, 2020 at 9:18 AM Jed Brown <jed at jedbrown.org> wrote:
> Not unless you pass -j (or export it in MAKEFLAGS).
So just run make -f ./gmakefile -j 8 if you want a parallel build?
  Matt
> On Sun, Oct 11, 2020, at 6:51 AM, Matthew Knepley wrote:
> On Sun, Oct 11, 2020 at 4:35 AM Barry Smith <bsmith at petsc.dev> wrote:
> On Oct 11, 2020, at 2:50 AM, Pierre Jolivet <pierre at joliv.et> wrote:
> This actually applies to all packages with builtafterpetsc = 1.
>   Yes, but now that petsc4py is part of the PETSc repository I would like
> to just alway have it turned on so now the rebuild is annoying.
> I think you want to do make libs instead of make all?
>   The problem is make libs is not parallel so much slower?
> make -f ./gmakefile is not parallel?
>   Matt
>   Barry
> Thanks,
> Pierre
> On 11 Oct 2020, at 9:36 AM, Barry Smith <bsmith at petsc.dev> wrote:
>   I change a single PETSc file and do make all that single file gets
> compiled but all of mpi4py and petsc4py get recompiled even though I have
> not changed any thing to affect them. No include files for example
> *** Building mpi4py ***
> *** Installing mpi4py ***
> To use mpi4py, add
> /Users/barrysmith/Src/petsc/arch-cleanup-dmd-domaindecomposition/lib to
> PYTHONPATH
> *** Building petsc4py ***
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20201011/66f65d0f/attachment.html>
