[petsc-dev] PETSc always recompiles mpi4py petsc4py even when it does not have too
Jed Brown
jed at jedbrown.org
Sun Oct 11 08:18:20 CDT 2020
Not unless you pass -j (or export it in MAKEFLAGS).
On Sun, Oct 11, 2020, at 6:51 AM, Matthew Knepley wrote:
> On Sun, Oct 11, 2020 at 4:35 AM Barry Smith <bsmith at petsc.dev> wrote:
>>> On Oct 11, 2020, at 2:50 AM, Pierre Jolivet <pierre at joliv.et> wrote:
>>> This actually applies to all packages with builtafterpetsc = 1.
>> Yes, but now that petsc4py is part of the PETSc repository I would like to just alway have it turned on so now the rebuild is annoying.
>>> I think you want to do make libs instead of make all?
>> The problem is make libs is not parallel so much slower?
> make -f ./gmakefile is not parallel?
> Matt
>> Barry
>>> Thanks,
>>> Pierre
>>>> On 11 Oct 2020, at 9:36 AM, Barry Smith <bsmith at petsc.dev> wrote:
>>>> I change a single PETSc file and do make all that single file gets compiled but all of mpi4py and petsc4py get recompiled even though I have not changed any thing to affect them. No include files for example
>>>> *** Building mpi4py ***
>>>> *** Installing mpi4py ***
>>>> To use mpi4py, add /Users/barrysmith/Src/petsc/arch-cleanup-dmd-domaindecomposition/lib to PYTHONPATH
>>>> *** Building petsc4py ***
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20201011/bc4d4c0e/attachment.html>
