[petsc-dev] Fwd: [coin-or/ADOL-C] Swig's Setup.py will default to lib64 which is inappropriate if the u… (#30)
Barry Smith
bsmith at petsc.dev
Sat Oct 10 21:20:02 CDT 2020
I am not suggesting we should set this up for PETSc just pointing out the possibility.
Barry
> Begin forwarded message:
> From: CLAassistant <notifications at github.com>
> Subject: Re: [coin-or/ADOL-C] Swig's Setup.py will default to lib64 which is inappropriate if the u… (#30)
> Date: October 10, 2020 at 9:05:25 PM CDT
> To: coin-or/ADOL-C <ADOL-C at noreply.github.com>
> Cc: Barry Smith <bsmith at mcs.anl.gov>, Author <author at noreply.github.com>
> Reply-To: coin-or/ADOL-C <reply+AAD5BOI6XVEPY4YZ53H4ALN5RZEWLEVBNHHCVVYX64 at reply.github.com>
> Message-Id: <coin-or/ADOL-C/pull/30/c706638144 at github.com>
> <https://cla-assistant.io/coin-or/ADOL-C?pullRequest=30>
> Thank you for your submission! We really appreciate it. Like many open source projects, we ask that you sign our Contributor License Agreement <https://cla-assistant.io/coin-or/ADOL-C?pullRequest=30> before we can accept your contribution.
> You have signed the CLA already but the status is still pending? Let us recheck <https://cla-assistant.io/check/coin-or/ADOL-C?pullRequest=30> it.
> You are receiving this because you authored the thread.
> Reply to this email directly, view it on GitHub <https://github.com/coin-or/ADOL-C/pull/30#issuecomment-706638144>, or unsubscribe <https://github.com/notifications/unsubscribe-auth/AAD5BOM3Q2YFURFOEFMVQW3SKEHGLANCNFSM4SLOH3DQ>.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20201010/5522f918/attachment-0001.html>
