[petsc-dev] Failure of mergecov
    Satish Balay
    balay at mcs.anl.gov
    Thu Oct  8 16:54:03 CDT 2020
> fatal: ambiguous argument 'origin/master...': unknown revision or path not in the working tree.
Likely a bug in this check [which I think is expected to create origin/master in the clone] ..
Satish
diff --git a/lib/petsc/bin/maint/check-merge-branch.sh b/lib/petsc/bin/maint/check-merge-branch.sh
index f590b9c646..3ba477c4af 100755
--- a/lib/petsc/bin/maint/check-merge-branch.sh
+++ b/lib/petsc/bin/maint/check-merge-branch.sh
@@ -1,6 +1,7 @@
 #!/bin/bash -e
 if [ ! -z ${CI_MERGE_REQUEST_TARGET_BRANCH_NAME+x} ]; then
+  git fetch -q --unshallow --no-tags +${CI_MERGE_REQUEST_TARGET_BRANCH_NAME}:remotes/origin/${CI_MERGE_REQUEST_TARGET_BRANCH_NAME}
   echo origin/${CI_MERGE_REQUEST_TARGET_BRANCH_NAME}
   exit 0
 fi
On Thu, 8 Oct 2020, Barry Smith wrote:
> git diff --name-only origin/master...' returned non-zero exit status 128.
>   I did a retry, let's see if that works.
>   I can protect this with a try so it won't crash CI and waste people's time.
>   I'll look at the log more closely later and see if I guess the cause.
>   Barry
> > On Oct 8, 2020, at 3:03 PM, Matthew Knepley <knepley at gmail.com> wrote:
> > Barry, I got this
> >   https://gitlab.com/petsc/petsc/-/jobs/780244679 <https://gitlab.com/petsc/petsc/-/jobs/780244679>
> > in this pipeline analysis
> >   https://gitlab.com/petsc/petsc/-/pipelines/199842334 <https://gitlab.com/petsc/petsc/-/pipelines/199842334>
> > I did not use the CI issue because this is about code.
> >   Thanks,
> >      Matt
> > What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> > -- Norbert Wiener
> > https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
