[petsc-dev] Failure of mergecov
    Barry Smith
    bsmith at petsc.dev
    Thu Oct  8 16:34:28 CDT 2020
git diff --name-only origin/master...' returned non-zero exit status 128.
  I did a retry, let's see if that works.
  I can protect this with a try so it won't crash CI and waste people's time.
  I'll look at the log more closely later and see if I guess the cause.
  Barry
> On Oct 8, 2020, at 3:03 PM, Matthew Knepley <knepley at gmail.com> wrote:
> Barry, I got this
>   https://gitlab.com/petsc/petsc/-/jobs/780244679 <https://gitlab.com/petsc/petsc/-/jobs/780244679>
> in this pipeline analysis
>   https://gitlab.com/petsc/petsc/-/pipelines/199842334 <https://gitlab.com/petsc/petsc/-/pipelines/199842334>
> I did not use the CI issue because this is about code.
>   Thanks,
>      Matt
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20201008/5fe93cb0/attachment.html>
