[petsc-dev] Kokkos error on SUMMIT
    Junchao Zhang
    junchao.zhang at gmail.com
    Fri Oct  2 15:06:44 CDT 2020
On Fri, Oct 2, 2020 at 3:02 PM Junchao Zhang <junchao.zhang at gmail.com>
wrote:
> On Fri, Oct 2, 2020 at 2:59 PM Mark Adams <mfadams at lbl.gov> wrote:
>> On Fri, Oct 2, 2020 at 3:15 PM Barry Smith <bsmith at petsc.dev> wrote:
>>>   Mark,
>>>   Looks like you are building Kokkos without CUDA.
>> Yes. This is a CPU build of Kokkos.
>>> You don't have --with-cuda on configure line that is used by Kokkos to
>>> determine what version to build.
>>>   Junchao,
>>>   I guess you need to test Kokkos Kernels without CUDA and HIP and make
>>> a few changes.
>> I'm trying with OpenMP right now. If you want CPU runs then asking for
>> OMP is not terrible.
> That is an interesting feature of Kokkos.
By the design, even 'device' memory is now the host memory. The computation
is still diverted to Kokkos backend.  In other words, petsc supports
multithreading through Kokkos.
>>>   Barry
>>> #if defined(PETSC_HAVE_CUDA)
>>>   #define WaitForKokkos() PetscCUDASynchronize ? (Kokkos::fence(),0) : 0;
>>> #elif defined(PETSC_HAVE_HIP)
>>>   #define WaitForKokkos() PetscHIPSynchronize ? (Kokkos::fence(),0) : 0;
>>> #endif
>>> > On Oct 2, 2020, at 11:47 AM, Mark Adams <mfadams at lbl.gov> wrote:
>>> > <configure.log><make.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20201002/7fc42f24/attachment.html>
