[petsc-dev] Kokkos error on SUMMIT
Junchao Zhang junchao.zhang at gmail.com
Fri Oct 2 15:02:41 CDT 2020
On Fri, Oct 2, 2020 at 2:59 PM Mark Adams <mfadams at lbl.gov> wrote:
> On Fri, Oct 2, 2020 at 3:15 PM Barry Smith <bsmith at petsc.dev> wrote:
>>   Mark,
>>   Looks like you are building Kokkos without CUDA.
> Yes. This is a CPU build of Kokkos.
>> You don't have --with-cuda on configure line that is used by Kokkos to
>> determine what version to build.
>>   Junchao,
>>   I guess you need to test Kokkos Kernels without CUDA and HIP and make a
>> few changes.
> I'm trying with OpenMP right now. If you want CPU runs then asking for OMP
> is not terrible.
That is an interesting feature of Kokkos.
>>   Barry
>> #if defined(PETSC_HAVE_CUDA)
>>   #define WaitForKokkos() PetscCUDASynchronize ? (Kokkos::fence(),0) : 0;
>> #elif defined(PETSC_HAVE_HIP)
>>   #define WaitForKokkos() PetscHIPSynchronize ? (Kokkos::fence(),0) : 0;
>> #endif
>> > On Oct 2, 2020, at 11:47 AM, Mark Adams <mfadams at lbl.gov> wrote:
>> > <configure.log><make.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20201002/9ea96139/attachment.html>
