[petsc-dev] Fwd: [petsc-users] new book introducing PETSc for PDEs
Jed Brown
jed at jedbrown.org
Mon Nov 2 16:59:44 CST 2020
Ed Bueler <elbueler at alaska.edu> writes:
>> You should be able to click "Add rule" here
>> https://github.com/bueler/p4pdes/settings/branches
> Nope. Try it. Restricting branches is not one of the options under
> "github pro" public repo ownership. (Nothing about the github
> manage access interface is informative about admins and/or
> collaborator permissions etc.)
> However, adding required MR reviews onto master is an option, and I can
> leave "Include Admins" unchecked; I have done that. I'll see if these
> settings are smooth for me.
I think that's what I meant. In any case, we use it in libceed and I see
the ability in other personal repositories. I'm not sure what's missing
from your view, but requiring MRs for non-admin (you) should be enough.
