[petsc-dev] Fwd: [petsc-users] new book introducing PETSc for PDEs
    Ed Bueler
    elbueler at alaska.edu
    Mon Nov  2 16:53:50 CST 2020
Including list.
Ed
---------- Forwarded message ---------
Date: Mon, Nov 2, 2020 at 1:53 PM
Subject: Re: [petsc-dev] [petsc-users] new book introducing PETSc for PDEs
To: Jed Brown <jed at jedbrown.org>
> You should be able to click "Add rule" here
> https://github.com/bueler/p4pdes/settings/branches
Nope.  Try it.  Restricting branches is not one of the options under
"github pro" public repo ownership.  (Nothing about the github
manage access interface is informative about admins and/or
collaborator permissions etc.)
However, adding required MR reviews onto master is an option, and I can
leave "Include Admins" unchecked; I have done that.   I'll see if these
settings are smooth for me.
Ed
On Mon, Nov 2, 2020 at 1:36 PM Jed Brown <jed at jedbrown.org> wrote:
> Ed Bueler <elbueler at alaska.edu> writes:
> > satish> Perhaps if some of us get this (create branch) access at
> > https://github.com/bueler/p4pdes - the workflow is slightly
> > satish> simplified [and a fork can be avoided which would require toggle
> of
> > giturl as the MR progresses between
> > satish> fork url and upstream url - and the commit-ids that change as the
> > upstream MR progresses..]
> > I appreciate the desire to avoid working in forks, so I went ahead and
> > invited Barry, Jed, Satish as collaborators on p4pdes.  Please let me
> know
> > if there are others to invite.
> Thanks. I don't think this materially changes the workflow, but it does
> mean PETSc's configure doesn't need to learn how to switch remotes in
> packages it downloads, and .../packages/p4pdes.py can just name commits so
> long as review in bueler/p4pdes just results in new commits rather than
> editing/rebasing the branch.
> > Indeed, I suppose my preferred workflow on p4pdes is for collaborators to
> > create branches and do MRs.  It looks like actually restricting
> > collaborators from pushing on master is not something I can do.  ("The
> > ability to restrict branches is a type of branch protection that's
> > available for public and private repositories owned by organizations in
> > GitHub Team, GitHub Enterprise Cloud, and GitHub Enterprise Server.")
> > Other forms of protecting master look like they add steps to my own
> (direct
> > and minimal) workflow on master.
Ed Bueler
Dept of Mathematics and Statistics
University of Alaska Fairbanks
Fairbanks, AK 99775-6660
306C Chapman
Ed Bueler
306C Chapman
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20201102/1f85f562/attachment.html>
