[petsc-dev] Globsearch fails for me when running tests
Jed Brown
jed at jedbrown.org
Sat Mar 28 11:29:06 CDT 2020
Matthew Knepley <knepley at gmail.com> writes:
>> > IIRC, the $(file ...) function does not work with stock make in macOS.
>> You're right; that is a make 4.0 feature. But developers who need
>> globsearch should have the ability to evade Apple's anti-GNU smear.
> Do we really have to make things hard on Mac to use something I use every
> day hundreds of times?
Are you still using make-3.81? Do you also use an Apple Newton?
You can still use search and searchin.
Scott can implement globsearch to call Python that calls make print-test
(listing tests on stdout) and returns the result on stdout. But it
can't pass the list all the tests on the command line.
