[petsc-dev] Globsearch fails for me when running tests
Scott Kruger
kruger at txcorp.com
Wed Mar 25 17:15:46 CDT 2020
Ugh -- this is ugly.
Can't we just tell users to either use the '%' syntax or recompile their
linux kernel?
Just kidding. I'll take a look.
Scott
On 3/25/20 3:48 PM, Jed Brown wrote:
> Scott, you can't pass '$(alltesttargets)' on the command line like this.
> TESTTARGETS := $(shell $(PYTHON) -c"import sys,fnmatch,itertools; m=[fnmatch.filter(sys.argv[2].split(),p) for p in sys.argv[1].split()]; print(' '.join(list(itertools.chain.from_iterable(m))))" '$(globsearch)' '$(alltesttargets)')
> For this feature, probably put them in an argsfile
> $(file >$(TESTDIR)/globsearch.args,$(alltesttargets))
> and make your Python read from that file. I don't know a way to pass it
> on stdin.
> Scott Kruger <kruger at txcorp.com> writes:
>> What platform?
>> On 3/25/20 3:20 PM, Stefano Zampini wrote:
>>> This was working before..
>>> [szampini at localhost petsc]$ make -f gmakefile.test test globsearch='dm*'
>>> make: execvp: /usr/bin/sh: Argument list too long
>>> Using MAKEFLAGS: -- globsearch=dm*
>>> # No tests run
>>> # No tests run
>>> # No tests run
>>> [szampini at localhost petsc]$ git branch
>>> * knepley/feature-dm-remove-hybrid
>>> [szampini at localhost petsc]$ make -v
>>> GNU Make 4.2.1
>>> Built for x86_64-redhat-linux-gnu
>>> Copyright (C) 1988-2016 Free Software Foundation, Inc.
>>> License GPLv3+: GNU GPL version 3 or later
>>> <http://gnu.org/licenses/gpl.html>
>>> This is free software: you are free to change and redistribute it.
>>> There is NO WARRANTY, to the extent permitted by law.
>> Tech-X Corporation kruger at txcorp.com
>> 5621 Arapahoe Ave, Suite A Phone: (720) 974-1841
>> Boulder, CO 80303 Fax: (303) 448-7756
