[petsc-dev] Globsearch fails for me when running tests
Jed Brown jed at jedbrown.org
Wed Mar 25 16:48:26 CDT 2020
Scott, you can't pass '$(alltesttargets)' on the command line like this.
  TESTTARGETS := $(shell $(PYTHON) -c"import sys,fnmatch,itertools; m=[fnmatch.filter(sys.argv[2].split(),p) for p in sys.argv[1].split()]; print(' '.join(list(itertools.chain.from_iterable(m))))" '$(globsearch)' '$(alltesttargets)')
For this feature, probably put them in an argsfile
  $(file >$(TESTDIR)/globsearch.args,$(alltesttargets))
and make your Python read from that file.  I don't know a way to pass it
on stdin.
Scott Kruger <kruger at txcorp.com> writes:
> What platform?
> On 3/25/20 3:20 PM, Stefano Zampini wrote:
>> This was working before..
>> [szampini at localhost petsc]$ make -f gmakefile.test test globsearch='dm*'
>> make: execvp: /usr/bin/sh: Argument list too long
>> Using MAKEFLAGS: -- globsearch=dm*
>> # No tests run
>> # No tests run
>> # No tests run
>> [szampini at localhost petsc]$ git branch
>> * knepley/feature-dm-remove-hybrid
>> [szampini at localhost petsc]$ make -v
>> GNU Make 4.2.1
>> Built for x86_64-redhat-linux-gnu
>> Copyright (C) 1988-2016 Free Software Foundation, Inc.
>> License GPLv3+: GNU GPL version 3 or later
>> <http://gnu.org/licenses/gpl.html>
>> This is free software: you are free to change and redistribute it.
>> There is NO WARRANTY, to the extent permitted by law.
> Tech-X Corporation               kruger at txcorp.com
> 5621 Arapahoe Ave, Suite A       Phone: (720) 974-1841
> Boulder, CO 80303                Fax:   (303) 448-7756
