[petsc-dev] Unions of IS and MatNest
    Matthew Knepley
    knepley at gmail.com
    Fri Mar 13 10:31:18 CDT 2020
On Fri, Mar 13, 2020 at 11:20 AM Pierre Jolivet <pierre.jolivet at enseeiht.fr>
wrote:
> On 13 Mar 2020, at 2:36 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Mar 13, 2020 at 3:19 AM Pierre Jolivet <pierre.jolivet at enseeiht.fr>
> wrote:
>> On 12 Mar 2020, at 11:40 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Thu, Mar 12, 2020 at 5:59 PM Jed Brown <jed at jedbrown.org> wrote:
>>> Pierre Jolivet <pierre.jolivet at enseeiht.fr> writes:
>>> > Hello,
>>> > Has there been any follow-up on this
>>> https://lists.mcs.anl.gov/pipermail/petsc-users/2015-January/024020.html
>>> > Given a 3x3 MatNest A = [A_00,0,0 ; 0,A_11,0 ; 0,0,A_22], I’d like to
>>> setup a two-way fieldsplit coupling [A_00,0 ; 0,A_11] and [A_22] but I
>>> can’t figure out the proper options.
>>> Are you looking for a Schur split or additive/multiplicative?
>> Don’t know yet which will perform best, do you have a specific solution
>> in mind for one scenario or the other?
>> I was mostly wondering if it was possible in a general context, not
>> taking -pc_fieldsplit_type into account.
>> -pc_fieldsplit_field_0 0,1 -pc_fieldsplit_field_1 2 -pc_fieldsplit_type
>> schur
>> These flags, used with my .cpp, yield:
>> [0]PETSC ERROR: Arguments are incompatible
>> [0]PETSC ERROR: To use Schur complement preconditioner you must have
>> exactly 2 fields
>> If I use -pc_fieldsplit_%d_fields <a,b,..> as advocated in the manual
>> (instead of -pc_fieldsplit_field_%d as you suggested), I get the same error.
> Okay it is  -pc_fieldsplit_%d_fields. When you use this, how many fields
> does it think you have?
> Three.
> In case it’s not clear, the MWE is at the bottom of my first email
> (nest.cpp).
> $ mpicxx nest.cpp -I$PETSC_DIR/$PETSC_ARCH/include -I$PETSC_DIR/include
> -L$PETSC_DIR/$PETSC_ARCH/lib -lpetsc
> $ ./a.out -pc_type fieldsplit -pc_fieldsplit_0_fields 0,1
> -pc_fieldsplit_1_fields 2 -pc_fieldsplit_type schur
> exactly 2 fields
>     Split info:
>     Split number 0 Defined by IS
>     Split number 1 Defined by IS
>     Split number 2 Defined by IS
Okay, I will run it.
  Matt
> Thanks,
> Pierre
>    Matt
>> I believe.
>>    Matt
>>> > Jed, in this answer
>>> https://lists.mcs.anl.gov/pipermail/petsc-users/2015-January/023993.html
>>> https://lists.mcs.anl.gov/pipermail/petsc-users/2015-January/023993.html>,
>>> you recommend not to use MatNest. What would you recommend instead?
>>> See src/snes/examples/tutorials/ex28.c for my preferred approach.
>> I’m not using DM, so in terms of Mat, I guess this example shows that I
>> pretty much need to reimplement the field splitting myself?
>> Thanks,
>> Pierre
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200313/2d1787ec/attachment.html>
