[petsc-dev] Unions of IS and MatNest
    Matthew Knepley
    knepley at gmail.com
    Fri Mar 13 08:36:13 CDT 2020
On Fri, Mar 13, 2020 at 3:19 AM Pierre Jolivet <pierre.jolivet at enseeiht.fr>
wrote:
> On 12 Mar 2020, at 11:40 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Mar 12, 2020 at 5:59 PM Jed Brown <jed at jedbrown.org> wrote:
>> Pierre Jolivet <pierre.jolivet at enseeiht.fr> writes:
>> > Hello,
>> > Has there been any follow-up on this
>> https://lists.mcs.anl.gov/pipermail/petsc-users/2015-January/024020.html
>> <https://lists.mcs.anl.gov/pipermail/petsc-users/2015-January/024020.html
>> > Given a 3x3 MatNest A = [A_00,0,0 ; 0,A_11,0 ; 0,0,A_22], I’d like to
>> setup a two-way fieldsplit coupling [A_00,0 ; 0,A_11] and [A_22] but I
>> can’t figure out the proper options.
>> Are you looking for a Schur split or additive/multiplicative?
> Don’t know yet which will perform best, do you have a specific solution in
> mind for one scenario or the other?
> I was mostly wondering if it was possible in a general context, not taking
> -pc_fieldsplit_type into account.
> -pc_fieldsplit_field_0 0,1 -pc_fieldsplit_field_1 2 -pc_fieldsplit_type
> schur
> These flags, used with my .cpp, yield:
> [0]PETSC ERROR: Arguments are incompatible
> [0]PETSC ERROR: To use Schur complement preconditioner you must have
> exactly 2 fields
> If I use -pc_fieldsplit_%d_fields <a,b,..> as advocated in the manual
> (instead of -pc_fieldsplit_field_%d as you suggested), I get the same error.
Okay it is  -pc_fieldsplit_%d_fields. When you use this, how many fields
does it think you have?
   Matt
> I believe.
>    Matt
>> > Jed, in this answer
>> https://lists.mcs.anl.gov/pipermail/petsc-users/2015-January/023993.html
>> <https://lists.mcs.anl.gov/pipermail/petsc-users/2015-January/023993.html>,
>> you recommend not to use MatNest. What would you recommend instead?
>> See src/snes/examples/tutorials/ex28.c for my preferred approach.
> I’m not using DM, so in terms of Mat, I guess this example shows that I
> pretty much need to reimplement the field splitting myself?
> Thanks,
> Pierre
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200313/b9eda9f7/attachment-0001.html>
