[petsc-dev] Unions of IS and MatNest
Pierre Jolivet
pierre.jolivet at enseeiht.fr
Thu Mar 12 16:53:45 CDT 2020
Hello,
Has there been any follow-up on this https://lists.mcs.anl.gov/pipermail/petsc-users/2015-January/024020.html <https://lists.mcs.anl.gov/pipermail/petsc-users/2015-January/024020.html>?
Given a 3x3 MatNest A = [A_00,0,0 ; 0,A_11,0 ; 0,0,A_22], I’d like to setup a two-way fieldsplit coupling [A_00,0 ; 0,A_11] and [A_22] but I can’t figure out the proper options.
Jed, in this answer https://lists.mcs.anl.gov/pipermail/petsc-users/2015-January/023993.html <https://lists.mcs.anl.gov/pipermail/petsc-users/2015-January/023993.html>, you recommend not to use MatNest. What would you recommend instead?
Even defining a 2x2 MatNest B = [B_00,0 ; 0,A_22] with B_00 = [A_00,0 ; 0,A_11] sounds bad to you?
Thanks for your help,
Pierre
PS: this is just a dummy example with 0s everywhere.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200312/fd6a6aef/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200312/fd6a6aef/attachment.obj>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200312/fd6a6aef/attachment-0001.html>
