[petsc-dev] Request for comments: allow C99 internally
Satish Balay
balay at mcs.anl.gov
Sat Mar 7 08:57:07 CST 2020
On Sat, 7 Mar 2020, Jed Brown wrote:
> Satish Balay <balay at mcs.anl.gov> writes:
> > On Fri, 6 Mar 2020, Jed Brown wrote:
> >> PetscInt some,several,variables;
> >> // code
> >> if (PetscDefined(HAVE_MAGIC)) {
> >> function(several,&variables);
> >> use(some,variables);
> > One minor issue: we haven't yet fixed up clang analyzer build. Likely this will be listed as 'dead code' block or something like that.
> As with #ifdef, accurate code coverage needs to be aggregated across
> multiple configurations. Are you aware of other problems?
None that I can think off now..
Satish
> >> This approach could also be used to avoid needing separate macros for
> >> every SETERRQ1-SETERRQ9, etc. I have an example implementation in this
> >> MR, and it passes the full pipeline (after relaxing the -std=c89
> >> -pedantic build).
> > These are in public includes. So apps using -std=c89 won't have access to this part of the API?
> Oh, I would keep the macros for a while (perhaps with gradual
> deprecation starting eventually), just define the new ones for supported
> dialects and use the new ones internally.
