[petsc-dev] Request for comments: allow C99 internally
Jed Brown
jed at jedbrown.org
Sat Mar 7 08:44:56 CST 2020
Satish Balay <balay at mcs.anl.gov> writes:
> On Fri, 6 Mar 2020, Jed Brown wrote:
>> PetscInt some,several,variables;
>> // code
>> if (PetscDefined(HAVE_MAGIC)) {
>> function(several,&variables);
>> use(some,variables);
> One minor issue: we haven't yet fixed up clang analyzer build. Likely this will be listed as 'dead code' block or something like that.
As with #ifdef, accurate code coverage needs to be aggregated across
multiple configurations. Are you aware of other problems?
>> This approach could also be used to avoid needing separate macros for
>> every SETERRQ1-SETERRQ9, etc. I have an example implementation in this
>> MR, and it passes the full pipeline (after relaxing the -std=c89
>> -pedantic build).
> These are in public includes. So apps using -std=c89 won't have access to this part of the API?
Oh, I would keep the macros for a while (perhaps with gradual
deprecation starting eventually), just define the new ones for supported
dialects and use the new ones internally.
