[petsc-dev] question on MatGolubKahanComputeExplicitOperator()
Barry Smith
bsmith at petsc.dev
Wed Jun 24 00:23:00 CDT 2020
MatGolubKahanComputeExplicitOperator() first verifies that C is the transpose of B, it then computes the transpose of B to do the MatMatMult().
1) Since C is the transpose of B isn't the second transpose not needed? Just use C instead of the BT?
2) If one knows the C = B' one can save the expensive check. Presumably if the entire large matrix is known to be symmetric one can skip the transpose check? The user
can provide this information with MatSetOption() when they build the matrix.
Thanks
Barry
static PetscErrorCode MatGolubKahanComputeExplicitOperator(Mat A,Mat B,Mat C,Mat *H,PetscReal gkbnu)
PetscErrorCode ierr;
Mat BT,T;
PetscReal nrmT,nrmB;
PetscFunctionBegin;
ierr = MatHermitianTranspose(C,MAT_INITIAL_MATRIX,&T);CHKERRQ(ierr); /* Test if augmented matrix is symmetric */
ierr = MatAXPY(T,-1.0,B,DIFFERENT_NONZERO_PATTERN);CHKERRQ(ierr);
ierr = MatNorm(T,NORM_1,&nrmT);CHKERRQ(ierr);
ierr = MatNorm(B,NORM_1,&nrmB);CHKERRQ(ierr);
if (nrmB > 0) {
if (nrmT/nrmB >= PETSC_SMALL) {
SETERRQ(PETSC_COMM_SELF,PETSC_ERR_ARG_WRONG,"Matrix is not symmetric/hermitian, GKB is not applicable.");
/* Compute augmented Lagrangian matrix H = A00 + nu*A01*A01'. This corresponds to */
/* setting N := 1/nu*I in [Ar13]. */
ierr = MatHermitianTranspose(B,MAT_INITIAL_MATRIX,&BT);CHKERRQ(ierr);
ierr = MatMatMult(B,BT,MAT_INITIAL_MATRIX,PETSC_DEFAULT,H);CHKERRQ(ierr); /* H = A01*A01' */
ierr = MatAYPX(*H,gkbnu,A,DIFFERENT_NONZERO_PATTERN);CHKERRQ(ierr); /* H = A00 + nu*A01*A01' */
ierr = MatDestroy(&BT);CHKERRQ(ierr);
ierr = MatDestroy(&T);CHKERRQ(ierr);
PetscFunctionReturn(0);
