[petsc-dev] Googling PetscMatlabEngine leads to 3.7 version
Barry Smith
bsmith at petsc.dev
Mon Jun 15 12:41:16 CDT 2020
Ahh, something missing in our processing for .cu files; new branch to fix the problem coming soon.
> On Jun 15, 2020, at 9:03 AM, Pierre Jolivet <pierre.jolivet at enseeiht.fr> wrote:
> Speaking of the website, wrong links are being generated in the documentation.
> https://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Mat/MATSEQDENSECUDA.html <https://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Mat/MATSEQDENSECUDA.html> has a link to https://www.mcs.anl.gov/petsc/petsc-dev/src/mat/impls/dense/seq/cudadensecuda.cu#MATSEQDENSECUDA <https://www.mcs.anl.gov/petsc/petsc-dev/src/mat/impls/dense/seq/cudadensecuda.cu#MATSEQDENSECUDA> which should read https://www.mcs.anl.gov/petsc/petsc-dev/src/mat/impls/dense/seq/cuda/densecuda.cu.html#MATSEQDENSECUDA <https://www.mcs.anl.gov/petsc/petsc-dev/src/mat/impls/dense/seq/cuda/densecuda.cu.html#MATSEQDENSECUDA> (notice the added / and .html)
> Thanks,
> Pierre
>> On 9 Jun 2020, at 7:52 PM, Satish Balay <balay at mcs.anl.gov <mailto:balay at mcs.anl.gov>> wrote:
>> Wrt different petsc versions - Its best to disable google from searching old versions.
>> I've updated robots.txt [it previously had some old values]
>> petsc at es:/mcs/web/research/projects/petsc$ cat robots.txt
>> User-agent: *
>> Disallow: bin
>> Disallow: old
>> Disallow: mirror
>> Disallow: NCSA-UIUC
>> Disallow: petsc-3.*
>> Disallow: petsc4py-3.*
>> Disallow: petsc-dev
>> Disallow: petsc-master
>> Disallow: style.css
>> [Assuming the above is not buggy] it should primarily index petsc-current and petsc4py-current
>> Wrt PetscMatlabEngine - duckduckgo finds
>> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PETSC_MATLAB_ENGINE_.html <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PETSC_MATLAB_ENGINE_.html>
>> but not:
>> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscMatlabEngine.html
>> So something is weird wrt search [within the same version]
>> Satish
>> On Tue, 9 Jun 2020, Barry Smith wrote:
>>> I think I know the problem; there are no links to PCMG from other PCMG* manual pages hence google does not find it or thinks it is unpopular so an older page with a small number of links has higher priority? PetscMatlabEngine has links so I am not sure if it is the same problem.
>>> Barry
>>>> On Jun 8, 2020, at 11:41 PM, Pierre Jolivet <pierre.jolivet at enseeiht.fr> wrote:
>>>> Googling PCMG is no fun either (and there is no actual reference to the current man page).
>>>> Thanks,
>>>> Pierre
>>>> <PCMG site_https___www.mcs.anl.gov_ - Google Search.pdf>
>>>>> On 9 Jun 2020, at 2:27 AM, Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> wrote:
>>>>> Googling PetscMatlabEngine leads to 3.7 version but PetscMatlabEngineDestroy leads to 3.13.
>>>>> Any idea why some of the manual pages don't point to the latest version?
>>>>> Barry
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200615/5de858cf/attachment.html>
