[petsc-dev] Googling PetscMatlabEngine leads to 3.7 version
    Pierre Jolivet
    pierre.jolivet at enseeiht.fr
    Mon Jun 15 09:03:14 CDT 2020
Speaking of the website, wrong links are being generated in the documentation.
https://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Mat/MATSEQDENSECUDA.html <https://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Mat/MATSEQDENSECUDA.html> has a link to https://www.mcs.anl.gov/petsc/petsc-dev/src/mat/impls/dense/seq/cudadensecuda.cu#MATSEQDENSECUDA <https://www.mcs.anl.gov/petsc/petsc-dev/src/mat/impls/dense/seq/cudadensecuda.cu#MATSEQDENSECUDA> which should read https://www.mcs.anl.gov/petsc/petsc-dev/src/mat/impls/dense/seq/cuda/densecuda.cu.html#MATSEQDENSECUDA <https://www.mcs.anl.gov/petsc/petsc-dev/src/mat/impls/dense/seq/cuda/densecuda.cu.html#MATSEQDENSECUDA> (notice the added / and .html)
Pierre
> On 9 Jun 2020, at 7:52 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> Wrt different petsc versions - Its best to disable google from searching old versions.
> I've updated robots.txt [it previously had some old values]
> petsc at es:/mcs/web/research/projects/petsc$ cat robots.txt
> User-agent: *
> Disallow: bin
> Disallow: old
> Disallow: mirror
> Disallow: NCSA-UIUC
> Disallow: petsc-3.*
> Disallow: petsc4py-3.*
> Disallow: petsc-dev
> Disallow: petsc-master
> Disallow: style.css
> [Assuming the above is not buggy]  it should primarily index petsc-current and petsc4py-current
> Wrt PetscMatlabEngine - duckduckgo finds
> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PETSC_MATLAB_ENGINE_.html
> but not:
> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscMatlabEngine.html
> So something is weird wrt search [within the same version]
> Satish
> On Tue, 9 Jun 2020, Barry Smith wrote:
>>   I think I know the problem; there are no links to PCMG from other PCMG*  manual pages hence google does not find it or thinks it is unpopular so an older page with a small number of links has higher priority? PetscMatlabEngine has links so I am not sure if it is the same problem.
>>   Barry
>>> On Jun 8, 2020, at 11:41 PM, Pierre Jolivet <pierre.jolivet at enseeiht.fr> wrote:
>>> Googling PCMG is no fun either (and there is no actual reference to the current man page).
>>> Thanks,
>>> Pierre
>>> <PCMG site_https___www.mcs.anl.gov_ - Google Search.pdf>
>>>> On 9 Jun 2020, at 2:27 AM, Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> wrote:
>>>>  Googling PetscMatlabEngine leads to 3.7 version but PetscMatlabEngineDestroy leads to 3.13.
>>>>  Any idea why some of the manual pages don't point to the latest version?
>>>>  Barry
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200615/858bba9a/attachment.html>
