[petsc-dev] Valgrind MPI-Related Errors
    Jed Brown
    jed at jedbrown.org
    Fri Jun  5 14:04:51 CDT 2020
Jacob Faibussowitsch <jacob.fai at gmail.com> writes:
> Sorry for late reply.
>> I'd welcome a PR to add options like --enable-g=meminit.
> In docker? Or in petsc? According to Satish petsc’s —download-mpich already does this by default.
https://github.com/jedbrown/jedbrown-dockerfiles
>>  I'd rather not make that general-purpose image use ch3:sock
> Which image are you referring to? The image I use is jedbrown/mpich-ccache which does ship MPICH configured with ch3:sock (see below).
> MPICH Version:    	3.3.2
> MPICH Release date:	Tue Nov 12 21:23:16 CST 2019
> MPICH Device:    	ch3:sock
> MPICH configure: 	--disable-wrapper-rpath --with-device=ch3:sock
> MPICH CC: 	gcc    -O2
> MPICH CXX: 	g++   -O2
> MPICH F77: 	gfortran   -O2
> MPICH FC: 	gfortran   -O2
> MPICH Custom Information:
> Best regards,
> (Jacob Fai - booss - oh - vitch)
> Cell: (312) 694-3391
>>> 2. (More a question for Jed) If I am using Jeds docker image anyways and we have CI/CD builds also using his docker images (correct me if I am wrong here) and a valgrind build in stage 3 why not include those build arguments in the MPICH included in the images? I think the valgrind build for CI/CD actually downloads and builds MPICH through petsc configure, is this because of the errors I detailed below?
>> I'd welcome a PR to add options like --enable-g=meminit.  I'd rather not
>> make that general-purpose image use ch3:sock because people also use it
>> (via Singularity or Shifter) for performance.  We could make a different
>> Docker image with ch3:sock.
