[petsc-dev] Valgrind MPI-Related Errors
Jed Brown
jed at jedbrown.org
Tue Jun 2 15:07:35 CDT 2020
Jacob Faibussowitsch <jacob.fai at gmail.com> writes:
> 2. (More a question for Jed) If I am using Jeds docker image anyways and we have CI/CD builds also using his docker images (correct me if I am wrong here) and a valgrind build in stage 3 why not include those build arguments in the MPICH included in the images? I think the valgrind build for CI/CD actually downloads and builds MPICH through petsc configure, is this because of the errors I detailed below?
I'd welcome a PR to add options like --enable-g=meminit. I'd rather not
make that general-purpose image use ch3:sock because people also use it
(via Singularity or Shifter) for performance. We could make a different
Docker image with ch3:sock.
