[petsc-dev] Question about MPICH device we use
Satish Balay
balay at mcs.anl.gov
Wed Jul 22 13:23:17 CDT 2020
Primarily because ch3:sock performance does not degrade in oversubscribe mode - which is developer friendly - i.e on your laptop.
And folks doing optimized runs should use a properly tuned MPI for their setup anyway.
In this case --download-mpich-device=ch3:nemesis is likely appropriate if using --download-mpich [and not using a separate/optimized MPI]
Having defaults that satisfy all use cases is not practical.
Satish
On Wed, 22 Jul 2020, Matthew Knepley wrote:
> We default to ch3:sock. Scott MacLachlan just had a long thread on the
> Firedrake list where it ended up that reconfiguring using ch3:nemesis had a
> 2x performance boost on his 16-core proc, and noticeable effect on the 4
> core speedup.
> Why do we default to sock?
> Thanks,
> Matt
