[petsc-dev] Question about MPICH device we use
Barry Smith bsmith at petsc.dev
Wed Jul 22 13:18:19 CDT 2020
  Because nemesis does function in a reasonable way when the system is oversubscribed, that is there are more MPI ranks than cores. Many users getting started have whatever number of cores  (4?) but want to run tests with a few more ranks, this is not feasible with nemesis. In addition with the test harness we don't need to worry about the oversubscription issue and can run any number of ranks on any system.
  A possible alternative which means digging in the guts slightly is to default to nemesis BUT at PetscInitialize() if the user has selected more ranks than cores, stop and tell them they can't do that with nemesis and they must use sock if they want to do that. For the CI we would always use sock.
   Barry
> On Jul 22, 2020, at 1:10 PM, Matthew Knepley <knepley at gmail.com> wrote:
> We default to ch3:sock. Scott MacLachlan just had a long thread on the Firedrake list where it ended up that reconfiguring using ch3:nemesis had a 2x performance boost on his 16-core proc, and noticeable effect on the 4 core speedup.
> Why do we default to sock?
>   Thanks,
>      Matt
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200722/e8e906de/attachment.html>
