[petsc-dev] C++ error
Mark Adams
mfadams at lbl.gov
Tue Jul 14 17:42:01 CDT 2020
On Tue, Jul 14, 2020 at 5:41 PM Satish Balay <balay at mcs.anl.gov> wrote:
> On Tue, 14 Jul 2020, Mark Adams wrote:
> > > BTW: With CI - you can start it, cancel it, and then re-run only
> selected
> > > jobs - so that unneeded jobs are avoided. [when debugging specific
> failures
> > > on specific jobs]
> > I did not see that. How do you select just one run? I can see how to
> rerun
> > it but it does not pull a new version AFAIK.
> A given pipeline corresponds to a given commit. So when you push new
> commits [for fixes] - you need a new pipeline.
> But - once you start this new pipeline - you can cancel it [after pre
> stage]
Ah yes, I see.
> And then 'rerun' selected jobs on this new pipeline. (click the circular
> toggle next to any given job)
> If the selected jobs succeed - and want to run the full pipeline - you can
> do this [from the top right corner]
> Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200714/46659e55/attachment.html>
