[petsc-dev] pipeline failure
Satish Balay
balay at mcs.anl.gov
Mon Jul 13 15:10:48 CDT 2020
Including relevant info is always useful.
I guess this is the build you are referring to.
https://gitlab.com/petsc/petsc/-/jobs/636537264
Ok - I tried this master and it builds fine - so the issue is with your branch.
And yes - this build is with '--with-single-library=0'
Satish
On Mon, 13 Jul 2020, Matthew Knepley wrote:
> Do these have -single-library ?
> Thanks,
> Matt
> On Mon, Jul 13, 2020 at 3:51 PM Mark Adams <mfadams at lbl.gov> wrote:
> > I am getting this error on two pipeline tests. They don't seem to have
> > anything to do with my branch. I have gotten these several times today.
> > /home/petsc/builds/KFnbdjNX/0/petsc/petsc/arch-ci-linux-cuda-single-cxx/lib/libpetscdm.so:
> > undefined reference to `DMPlexSNESComputeJacobianFEM'
> > undefined reference to `TSGetDM'
> > collect2: error: ld returned 1 exit status
> > make[2]: *** [arch-ci-linux-cuda-single-cxx/tests/mat/tests/ex240] Error 1
> > make[2]: *** Waiting for unfinished jobs....
> > gmakefile.test:185: recipe for target
> > 'arch-ci-linux-cuda-single-cxx/tests/mat/tests/ex240' failed
> > make[1]: *** [allgtest-tap] Error 2
> > /home/petsc/builds/KFnbdjNX/0/petsc/petsc/lib/petsc/conf/test.common:26:
> > recipe for target 'allgtest-tap' failed
> > GNUmakefile:17: recipe for target 'allgtests-tap' failed
> > make: *** [allgtests-tap] Error 2
