[petsc-dev] pipeline failure
Mark Adams mfadams at lbl.gov
Mon Jul 13 15:08:41 CDT 2020
On Mon, Jul 13, 2020 at 4:01 PM Matthew Knepley <knepley at gmail.com> wrote:
> Do these have -single-library ?
This was in a single configuration, but it also happened in this one:
/scratch/svcpetsc/glci-builds/qanz_veh/0/petsc/petsc/arch-ci-linux-pkgs-cxx-mlib/lib/libpetscdm.so:
undefined reference to `TSGetDM'
undefined reference to `DMPlexSNESComputeJacobianFEM'
collect2: error: ld returned 1 exit status
gmakefile.test:185: recipe for target
'arch-ci-linux-pkgs-cxx-mlib/tests/mat/tests/ex96' failed
make[2]: *** [arch-ci-linux-pkgs-cxx-mlib/tests/mat/tests/ex96] Error 1
make[2]: *** Waiting for unfinished jobs....
/scratch/svcpetsc/glci-builds/qanz_veh/0/petsc/petsc/lib/petsc/conf/test.common:26:
recipe for target 'allgtest-tap' failed
make[1]: *** [allgtest-tap] Error 2
GNUmakefile:17: recipe for target 'allgtests-tap' failed
make: *** [allgtests-tap] Error 2
Running after_script
>   Thanks,
>      Matt
> On Mon, Jul 13, 2020 at 3:51 PM Mark Adams <mfadams at lbl.gov> wrote:
>> I am getting this error on two pipeline tests. They don't seem to have
>> anything to do with my branch. I have gotten these several times today.
>> /home/petsc/builds/KFnbdjNX/0/petsc/petsc/arch-ci-linux-cuda-single-cxx/lib/libpetscdm.so:
>> make[2]: *** [arch-ci-linux-cuda-single-cxx/tests/mat/tests/ex240] Error 1
>> 'arch-ci-linux-cuda-single-cxx/tests/mat/tests/ex240' failed
>> /home/petsc/builds/KFnbdjNX/0/petsc/petsc/lib/petsc/conf/test.common:26:
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200713/78b56fa1/attachment.html>
