[petsc-dev] gcc 10
Matthew Knepley
knepley at gmail.com
Mon Jul 13 14:54:14 CDT 2020
On Mon, Jul 13, 2020 at 3:50 PM Mark Adams <mfadams at lbl.gov> wrote:
> On Mon, Jul 13, 2020 at 1:40 PM Jed Brown <jed at jedbrown.org> wrote:
>> I don't know what failure you're referring to. The C++ complex thing
>> might have been a matter of the antique compiler.
> The failure was fixed with -fallow_ .... but it gave warnings.
Mark, can you try Barry's fix, changing the declaration of
PetscObjectSetName()?
Matt
>> Matthew Knepley <knepley at gmail.com> writes:
>> > Why did Mark have the gcc 10 failure on our example. Was it something
>> with
>> > did in it?
>> > Matt
>> > On Mon, Jul 13, 2020 at 12:43 PM Jed Brown <jed at jedbrown.org> wrote:
>> >> You want this for PETSc or for external packages? We add it for a
>> bunch
>> >> of external packages. I've been building PETSc with gcc/gfortran-10
>> for
>> >> months now.
>> >> > Do we have gfortran from gcc 10 running anywhere? We need a check to
>> >> enable
>> >> > -fallow-argument-mismatch
>> >> > from configure. Should be as simple as compiling Fortran which has
>> >> > PetscObjectSetName() in it.
>> >> > Thanks,
>> >> > Matt
>> >> > What most experimenters take for granted before they begin their
>> >> > experiments is infinitely more interesting than any results to which
>> >> their
>> >> > experiments lead.
>> >> > -- Norbert Wiener
>> >> > https://www.cse.buffalo.edu/~knepley/ <
>> >> http://www.cse.buffalo.edu/~knepley/>
>> their
>> > experiments lead.
>> > -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200713/b92c452c/attachment.html>
