[petsc-dev] gcc 10
Mark Adams
mfadams at lbl.gov
Mon Jul 13 14:50:41 CDT 2020
On Mon, Jul 13, 2020 at 1:40 PM Jed Brown <jed at jedbrown.org> wrote:
> I don't know what failure you're referring to. The C++ complex thing
> might have been a matter of the antique compiler.
The failure was fixed with -fallow_ .... but it gave warnings.
> Matthew Knepley <knepley at gmail.com> writes:
> > Why did Mark have the gcc 10 failure on our example. Was it something
> with
> > did in it?
> > Matt
> > On Mon, Jul 13, 2020 at 12:43 PM Jed Brown <jed at jedbrown.org> wrote:
> >> You want this for PETSc or for external packages? We add it for a bunch
> >> of external packages. I've been building PETSc with gcc/gfortran-10 for
> >> months now.
> >> > Do we have gfortran from gcc 10 running anywhere? We need a check to
> >> enable
> >> > -fallow-argument-mismatch
> >> > from configure. Should be as simple as compiling Fortran which has
> >> > PetscObjectSetName() in it.
> >> > Thanks,
> >> > Matt
> >> > What most experimenters take for granted before they begin their
> >> > experiments is infinitely more interesting than any results to which
> >> their
> >> > experiments lead.
> >> > -- Norbert Wiener
> >> > https://www.cse.buffalo.edu/~knepley/ <
> >> http://www.cse.buffalo.edu/~knepley/>
> their
> > experiments lead.
> > -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200713/2652f873/attachment.html>
