[petsc-dev] gcc 10
    Matthew Knepley
    knepley at gmail.com
    Mon Jul 13 12:34:48 CDT 2020
Why did Mark have the gcc 10 failure on our example. Was it something with
did in it?
   Matt
On Mon, Jul 13, 2020 at 12:43 PM Jed Brown <jed at jedbrown.org> wrote:
> You want this for PETSc or for external packages?  We add it for a bunch
> of external packages.  I've been building PETSc with gcc/gfortran-10 for
> months now.
> Matthew Knepley <knepley at gmail.com> writes:
> > Do we have gfortran from gcc 10 running anywhere? We need a check to
> enable
> >   -fallow-argument-mismatch
> > from configure. Should be as simple as compiling Fortran which has
> > PetscObjectSetName() in it.
> >   Thanks,
> >       Matt
> > What most experimenters take for granted before they begin their
> > experiments is infinitely more interesting than any results to which
> their
> > experiments lead.
> > -- Norbert Wiener
> > https://www.cse.buffalo.edu/~knepley/ <
> http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200713/359c0312/attachment.html>
