[petsc-dev] Windows error in pipeline with cxx file
Sun Jul 12 12:58:08 CDT 2020
And if kokkos won't have a configure option - and would always work with any c++ compiler - you can use:
diff --git a/src/dm/impls/plex/landau/kokkos/makefile b/src/dm/impls/plex/landau/kokkos/makefile
index 04504b4bf5..faa59fe0ff 100644
--- a/src/dm/impls/plex/landau/kokkos/makefile
+++ b/src/dm/impls/plex/landau/kokkos/makefile
@@ -1,3 +1,5 @@
+#requireslanguage CPP
 -include ../../../../../../petscdir.mk
 ALL: lib
[with corresponding #ifdef wrappers for all calls to functionality in these sources]
Satish
On Sun, 12 Jul 2020, Satish Balay via petsc-dev wrote:
> This build is with --with-cxx=0 - so .cxx source-files shouldn't get compiled.
> I'm not sure what the mechanism we have for disabling compile of cxx sources when --with-cxx=0 is used.
> Checking -  I see most of the cxx sources are tied to external-packages - and the corresponding package configure enforces c++ requirement
> How is kokkos enabled? Is there no --download-kokkos [or equivalent] needed in configure for kokkos?
> Note --with-cxx=0 - likely g++ is somehow getting picked up here [ with /usr/include/stdio.h] - resulting in failure
> Satish
> On Sun, 12 Jul 2020, Mark Adams wrote:
> > I am getting pipeline errors for  adams/feature-dmplex-snes-landau on
> > Windows-uni. mswin-gnu is fine.
> > There are lots of errors, here is the start. I've tried to match
> > mat/viennacl, which has .cxx files, w/o luck.
> > Any ideas?
> > Thanks,
> > Mark
> >         CXX
> > arch-ci-mswin-uni/obj/dm/impls/plex/landau/kokkos/landau_kokkos.o
> > In file included from /usr/include/stdio.h:61,
> >                  from
> > /home/glci2/builds/p34_q_s8/0/petsc/petsc/include/petscsys.h:225,
> >                  from
> > /home/glci2/builds/p34_q_s8/0/petsc/petsc/include/petscis.h:7,
> >                  from
> > /home/glci2/builds/p34_q_s8/0/petsc/petsc/include/petscvec.h:9,
> >                  from
> > /home/glci2/builds/p34_q_s8/0/petsc/petsc/include/petscmat.h:6,
> >                  from
> > /home/glci2/builds/p34_q_s8/0/petsc/petsc/include/petsc/private/dmpleximpl.h:4,
> >                  from
> > /home/glci2/builds/p34_q_s8/0/petsc/petsc/src/dm/impls/plex/landau/kokkos/landau_kokkos.cxx:5:
> > /usr/include/sys/types.h:165:18: error: conflicting declaration ‘typedef
> > __uid_t uid_t’
> >   165 | typedef __uid_t  uid_t;  /* user id */
