[petsc-dev] Windows error in pipeline with cxx file
Sun Jul 12 12:36:08 CDT 2020
This build is with --with-cxx=0 - so .cxx source-files shouldn't get compiled.
I'm not sure what the mechanism we have for disabling compile of cxx sources when --with-cxx=0 is used.
Checking -  I see most of the cxx sources are tied to external-packages - and the corresponding package configure enforces c++ requirement
How is kokkos enabled? Is there no --download-kokkos [or equivalent] needed in configure for kokkos?
Note --with-cxx=0 - likely g++ is somehow getting picked up here [ with /usr/include/stdio.h] - resulting in failure
Satish
On Sun, 12 Jul 2020, Mark Adams wrote:
> I am getting pipeline errors for  adams/feature-dmplex-snes-landau on
> Windows-uni. mswin-gnu is fine.
> There are lots of errors, here is the start. I've tried to match
> mat/viennacl, which has .cxx files, w/o luck.
> Any ideas?
> Thanks,
> Mark
>         CXX
> arch-ci-mswin-uni/obj/dm/impls/plex/landau/kokkos/landau_kokkos.o
> In file included from /usr/include/stdio.h:61,
>                  from
> /home/glci2/builds/p34_q_s8/0/petsc/petsc/include/petscsys.h:225,
>                  from
> /home/glci2/builds/p34_q_s8/0/petsc/petsc/include/petscis.h:7,
>                  from
> /home/glci2/builds/p34_q_s8/0/petsc/petsc/include/petscvec.h:9,
>                  from
> /home/glci2/builds/p34_q_s8/0/petsc/petsc/include/petscmat.h:6,
>                  from
> /home/glci2/builds/p34_q_s8/0/petsc/petsc/include/petsc/private/dmpleximpl.h:4,
>                  from
> /home/glci2/builds/p34_q_s8/0/petsc/petsc/src/dm/impls/plex/landau/kokkos/landau_kokkos.cxx:5:
> /usr/include/sys/types.h:165:18: error: conflicting declaration ‘typedef
> __uid_t uid_t’
>   165 | typedef __uid_t  uid_t;  /* user id */
