[petsc-dev] how do see artifacts?
    Balay, Satish
    balay at mcs.anl.gov
    Mon Jan 20 13:09:34 CST 2020
Works fine for me from safari. Attaching screenshot.
Perhaps 'clean history' will help? [safari does not show what history it cleans - cache, site-preferences? etc..]
Satish
On Mon, 20 Jan 2020, Smith, Barry F. via petsc-dev wrote:
>    Do they link with iCloud? ☠️
> > On Jan 20, 2020, at 5:07 AM, Matthew Knepley <knepley at gmail.com> wrote:
> > Try Firefox or Chrome?
> >    Matt
> > On Sun, Jan 19, 2020 at 11:41 PM Smith, Barry F. via petsc-dev <petsc-dev at mcs.anl.gov> wrote:
> > > On Jan 19, 2020, at 10:39 PM, Jed Brown <jed at jedbrown.org> wrote:
> > > "Smith, Barry F. via petsc-dev" <petsc-dev at mcs.anl.gov> writes:
> > >>  I have no left hand side.
> > > Right hand side?  I certainly see them.  Are you using a funny browser?
> >   Apple's :-)
> > >>  If I grab the left hand side with the mouse and pull it in or out
> > >>  sometimes I get the left hand panel, sometimes not.
> > >>   Barry
> > >>> On Jan 19, 2020, at 10:16 PM, Balay, Satish <balay at mcs.anl.gov> wrote:
> > >>> For some reason I can't access this job URL anymore. Ok checking a different one
> > >>> https://gitlab.com/petsc/petsc/-/jobs/407945185
> > >>> Attaching what I see [with the 'artifact' section in the right side column]
> > >>> Satish
> > >>>>> On Jan 19, 2020, at 7:13 PM, Balay, Satish <balay at mcs.anl.gov> wrote:
> > >>>>> For which job are you seeing this problem?
> > >>>>> For ex: https://gitlab.com/petsc/petsc/-/jobs/408092654 has
> > >>>> Where? I got to that page and it has the big black scrolling of the run output at the top it has a trash can and up and down arrows for the top and bottom of the file and a button for the raw data. No links or anything to artifacts.
> > >>>>  Do you literally need to type artifacts/file/arch-linux2-c-opt/lib/petsc/conf/configure.log in the address bar in the browser to find them?
> > >>>>> https://gitlab.com/petsc/petsc/-/jobs/408092654/artifacts/download
> > >>>>> https://gitlab.com/petsc/petsc/-/jobs/408092654/artifacts/browse
> > >>>>> I usually browse and look for configure.log for ex:
> > >>>>> https://gitlab.com/petsc/petsc/-/jobs/408092654/artifacts/file/arch-linux2-c-opt/lib/petsc/conf/configure.log
> > >>>>> Satish
> > >>>>> On Sun, 19 Jan 2020, Smith, Barry F. via petsc-dev wrote:
> > >>>>>> With the new Gitlab interfaces how do you see the artifacts for failed pipelines/tests? I can't find them anywhere. It just takes me straight to the output with no sidebar for artifacts?
> > >>>>>>  Thanks
> > >>>>>>    Barry
> > >>> <gitlab-artifacts.png>
> > What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> > -- Norbert Wiener
> > https://www.cse.buffalo.edu/~knepley/
Type: image/png
Desc: safari-gitlab.png
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200120/223366ba/attachment-0001.png>
