[petsc-dev] how do see artifacts?
Smith, Barry F.
bsmith at mcs.anl.gov
Mon Jan 20 07:23:34 CST 2020
Do they link with iCloud? ☠️
> On Jan 20, 2020, at 5:07 AM, Matthew Knepley <knepley at gmail.com> wrote:
> Try Firefox or Chrome?
> Matt
> On Sun, Jan 19, 2020 at 11:41 PM Smith, Barry F. via petsc-dev <petsc-dev at mcs.anl.gov> wrote:
> > On Jan 19, 2020, at 10:39 PM, Jed Brown <jed at jedbrown.org> wrote:
> > "Smith, Barry F. via petsc-dev" <petsc-dev at mcs.anl.gov> writes:
> >> I have no left hand side.
> > Right hand side? I certainly see them. Are you using a funny browser?
> Apple's :-)
> >> If I grab the left hand side with the mouse and pull it in or out
> >> sometimes I get the left hand panel, sometimes not.
> >> Barry
> >>> On Jan 19, 2020, at 10:16 PM, Balay, Satish <balay at mcs.anl.gov> wrote:
> >>> For some reason I can't access this job URL anymore. Ok checking a different one
> >>> https://gitlab.com/petsc/petsc/-/jobs/407945185
> >>> Attaching what I see [with the 'artifact' section in the right side column]
> >>> Satish
> >>> On Mon, 20 Jan 2020, Smith, Barry F. via petsc-dev wrote:
> >>>>> On Jan 19, 2020, at 7:13 PM, Balay, Satish <balay at mcs.anl.gov> wrote:
> >>>>> For which job are you seeing this problem?
> >>>>> For ex: https://gitlab.com/petsc/petsc/-/jobs/408092654 has
> >>>> Where? I got to that page and it has the big black scrolling of the run output at the top it has a trash can and up and down arrows for the top and bottom of the file and a button for the raw data. No links or anything to artifacts.
> >>>> Do you literally need to type artifacts/file/arch-linux2-c-opt/lib/petsc/conf/configure.log in the address bar in the browser to find them?
> >>>>> https://gitlab.com/petsc/petsc/-/jobs/408092654/artifacts/download
> >>>>> https://gitlab.com/petsc/petsc/-/jobs/408092654/artifacts/browse
> >>>>> I usually browse and look for configure.log for ex:
> >>>>> https://gitlab.com/petsc/petsc/-/jobs/408092654/artifacts/file/arch-linux2-c-opt/lib/petsc/conf/configure.log
> >>>>> Satish
> >>>>> On Sun, 19 Jan 2020, Smith, Barry F. via petsc-dev wrote:
> >>>>>> With the new Gitlab interfaces how do you see the artifacts for failed pipelines/tests? I can't find them anywhere. It just takes me straight to the output with no sidebar for artifacts?
> >>>>>> Thanks
> >>>>>> Barry
> >>> <gitlab-artifacts.png>
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
