[petsc-dev] ccache tips?
    Jed Brown
    jed at jedbrown.org
    Fri Jan 17 11:37:18 CST 2020
"Balay, Satish via petsc-dev" <petsc-dev at mcs.anl.gov> writes:
> I have ccache setup automatically on my linux box.
> balay at sb /home/balay
> $ which gcc
> /usr/lib64/ccache/gcc
> i.e the	easiest thing to do is update PATH. For ex on OSX [where its not automatically setup] - I have it installed via brew and:
> export PATH=/usr/local/opt/ccache/libexec:$PATH
Yep, this is good if you want use of ccache to be always-on.  That
directory just contains symlinks to the ccache executable, which checks
argv[0] and looks for the next one in PATH.
