[petsc-dev] Failure in Master
    Balay, Satish
    balay at mcs.anl.gov
    Wed Jan  1 15:10:11 CST 2020
pushed now.
Satish
On Wed, 1 Jan 2020, Balay, Satish wrote:
> Testing a fix at https://gitlab.com/petsc/petsc/pipelines/106492444 [will push to master on success]
> Satish
> On Wed, 1 Jan 2020, Pierre Jolivet wrote:
> > Missing output update in this commit https://gitlab.com/petsc/petsc/commit/87cb359fa4996f32ef63682124a591bf50d6fb2c <https://gitlab.com/petsc/petsc/commit/87cb359fa4996f32ef63682124a591bf50d6fb2c> ?
> > Thanks,
> > Pierre
> > > On 1 Jan 2020, at 6:39 PM, Matthew Knepley <knepley at gmail.com> wrote:
> > > Does anyone else see this?
> > > not ok diff-ts_tutorials_power_grid-ex9opt_2 # Error code: 1
> > > 5631         TEST arch-ci-mswin-uni/tests/counts/ts_tutorials-ex18_adv_delta_yper_fim_0.counts
> > > 5632 #	4c4
> > > 5633 #	<   Testing hand-coded Gradient, if (for double precision runs) ||G - Gfd||_F/||G||_F is
> > > 5634 #	---
> > > 5635 #	>   Testing hand-coded Gradient, if (for double precision runs) ||G - Gfd||/||G|| is
> > > 5636
> > > I rebased to master, but maybe something went wrong? Barry, do you know who was working on this? I got this here:
> > >    https://gitlab.com/petsc/petsc/pipelines/106488177 <https://gitlab.com/petsc/petsc/pipelines/106488177>
> > >   Thanks,
> > >      Matt
> > > What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> > > -- Norbert Wiener
> > > https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
