[petsc-dev] Failure in Master
Balay, Satish
balay at mcs.anl.gov
Wed Jan 1 12:13:23 CST 2020
Testing a fix at https://gitlab.com/petsc/petsc/pipelines/106492444 [will push to master on success]
Satish
On Wed, 1 Jan 2020, Pierre Jolivet wrote:
> Missing output update in this commit https://gitlab.com/petsc/petsc/commit/87cb359fa4996f32ef63682124a591bf50d6fb2c <https://gitlab.com/petsc/petsc/commit/87cb359fa4996f32ef63682124a591bf50d6fb2c> ?
> Thanks,
> Pierre
> > On 1 Jan 2020, at 6:39 PM, Matthew Knepley <knepley at gmail.com> wrote:
> > Does anyone else see this?
> > not ok diff-ts_tutorials_power_grid-ex9opt_2 # Error code: 1
> > 5631 TEST arch-ci-mswin-uni/tests/counts/ts_tutorials-ex18_adv_delta_yper_fim_0.counts
> > 5632 # 4c4
> > 5633 # < Testing hand-coded Gradient, if (for double precision runs) ||G - Gfd||_F/||G||_F is
> > 5634 # ---
> > 5635 # > Testing hand-coded Gradient, if (for double precision runs) ||G - Gfd||/||G|| is
> > 5636
> > I rebased to master, but maybe something went wrong? Barry, do you know who was working on this? I got this here:
> > https://gitlab.com/petsc/petsc/pipelines/106488177 <https://gitlab.com/petsc/petsc/pipelines/106488177>
> > Thanks,
> > Matt
> > What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> > -- Norbert Wiener
> > https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
