[petsc-dev] Fwd: [petsc-users] Matrix-free method in PETSc
Smith, Barry F.
bsmith at mcs.anl.gov
Tue Feb 18 21:10:10 CST 2020
In the past you needed a brain to get a Stanford email account
Begin forwarded message:
From: Yuyun Yang <yyang85 at stanford.edu<mailto:yyang85 at stanford.edu>>
Subject: Re: [petsc-users] Matrix-free method in PETSc
Date: February 18, 2020 at 8:26:11 AM CST
To: Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>>
Cc: "Smith, Barry F." <bsmith at mcs.anl.gov<mailto:bsmith at mcs.anl.gov>>, "petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>" <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>
Thanks. Also, when using KSP, would the syntax be KSPSetOperators(ksp,A,A)? Since you mentioned preconditioners are not generally used for matrix-free operators, I wasn’t sure whether I should still put “A” in the Pmat field.
Is it still possible to use TS in conjunction with the matrix-free operator? I’d like to create a simple test case that solves the 1d heat equation implicitly with variable coefficients, but didn’t know how the time stepping can be set up.
Yuyun
From: Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>>
Date: Tuesday, February 18, 2020 at 9:23 PM
To: Yuyun Yang <yyang85 at stanford.edu<mailto:yyang85 at stanford.edu>>
On Tue, Feb 18, 2020 at 8:20 AM Yuyun Yang <yyang85 at stanford.edu<mailto:yyang85 at stanford.edu>> wrote:
Thanks for the clarification.
Got one more question: if I have variable coefficients, my stencil will be updated at every time step, so will the coefficients in myMatMult. In that case, is it necessary to destroy the shell matrix and create it all over again, or can I use it as it is, only calling the stencil update function, assuming the result will be passed into the matrix operation automatically?
You update the information in the context associated with the shell matrix. No need to destroy it.
Matt
Yuyun
On 2/18/20, 7:34 AM, "Smith, Barry F." <bsmith at mcs.anl.gov<mailto:bsmith at mcs.anl.gov>> wrote:
> On Feb 17, 2020, at 7:56 AM, Yuyun Yang <yyang85 at stanford.edu<mailto:yyang85 at stanford.edu>> wrote:
> Hello,
> I actually have a question about the usage of DMDA since I'm quite new to this. I wonder if the DMDA suite of functions can be directly called on vectors created from VecCreate?
Yes, but you have to make sure the ones you create have the same sizes and parallel layouts. Generally best to get them from the DMDA or VecDuplicate() than the hassle of figuring out sizes.
> Or the vectors have to be formed by DMDACreateGlobalVector? I'm also not sure about what the dof and stencil width arguments do.
> I'm still unsure about the usage of MatCreateShell and MatShellSetOperation, since it seems that MyMatMult should still have 3 inputs just like MatMult (the matrix and two vectors). Since I'm not forming the matrix, does that mean the matrix input is meaningless but still needs to exist for the sake of this format?
Well the matrix input is your shell matrix so it likely has information you need to do your multiply routine. MatShellGetContext() (No you do not want to put your information about the matrix stencil inside global variables!)
> After I create such a shell matrix, can I use it like a regular matrix in KSP and utilize preconditioners?
> Thanks!
> Yuyun
> From: petsc-users <petsc-users-bounces at mcs.anl.gov<mailto:petsc-users-bounces at mcs.anl.gov>> on behalf of Yuyun Yang <yyang85 at stanford.edu<mailto:yyang85 at stanford.edu>>
> Sent: Sunday, February 16, 2020 3:12 AM
> To: Smith, Barry F. <bsmith at mcs.anl.gov<mailto:bsmith at mcs.anl.gov>>
> Cc: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov> <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>
> Thank you, that is very helpful information indeed! I will try it and send you my code when it works.
> Best regards,
> Yuyun
> From: Smith, Barry F. <bsmith at mcs.anl.gov<mailto:bsmith at mcs.anl.gov>>
> Sent: Saturday, February 15, 2020 10:02 PM
> Yuyun,
> If you are speaking about using a finite difference stencil on a structured grid where you provide the Jacobian vector products yourself by looping over the grid doing the stencil operation we unfortunately do not have exactly that kind of example.
> But it is actually not difficult. I suggest starting with src/ts/examples/tests/ex22.c It computes the sparse matrix explicitly with FormIJacobian()
> What you need to do is instead in main() use MatCreateShell() and MatShellSetOperation(,MATOP_MULT,(void (*)(void))MyMatMult) then provide the routine MyMatMult() to do your stencil based matrix free product; note that you can create this new routine by taking the structure of IFunction() and reorganizing it to do the Jacobian product instead. You will need to get the information about the shell matrix size on each process by calling DMDAGetCorners().
> You will then remove the explicit computation of the Jacobian, and also remove the Event stuff since you don't need it.
> Extending to 2 and 3d is straight forward.
> Any questions let us know.
> Barry
> If you like this would make a great merge request with your code to improve our examples.
> > On Feb 15, 2020, at 9:42 PM, Yuyun Yang <yyang85 at stanford.edu<mailto:yyang85 at stanford.edu>> wrote:
> > Hello team,
> > I wanted to apply the Krylov subspace method to a matrix-free implementation of a stencil, such that the iterative method acts on the operation without ever constructing the matrix explicitly (for example, when doing backward Euler).
> > I'm not sure whether there is already an example for that somewhere. If so, could you point me to a relevant example?
> > Thank you!
> > Best regards,
> > Yuyun
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200219/dd59d54c/attachment-0001.html>
