[petsc-dev] CI update: please rebase before starting test pipelines
Sat Feb 15 18:57:20 CST 2020
PETSc devs using CI at gitlab,
One of the CI builds is failing - and the fix for it is now in latest maint/master [as of now].
All new test pipelines require this fix to succeed.
So please rebase your branch [over maint or master - as appropriate] before submitting any new test pipelines. i.e:
git checkout feature-branch
git fetch
git rebase origin/master [or origin/maint] # Note: do not skip 'origin/' as listed here
If the feature branch is not rebased - it will be stuck at stage-2 job arch-ci-linux-gcc-complex-opt.
To verify if a feature-branch has this fix - check with:
git branch --contains c0dad76995 feature-branch
Satish
On Thu, 30 Jan 2020, Satish Balay via petsc-dev wrote:
> To clarify:
> CI uses .gitlab-ci.yaml from the branch - and not the latest from
> maint/master - so if your branch has old version of this file, and start
> a pipeline on it - it will get stuck - and timeout.
> To determine if your branch has this .gitlab-ci.yaml change [requiring
> a rebase] - see if it has the commit:
> git branch --contains 0b416d8e105a765da5769e4b7feab5986dc829a2
> Satish
> > With the current CI changes - before starting a test pipeline on a
> > branch at gitlab, its best to rebase the branch over current master as
> > of now [or maint - if appropriate].
> > If a test pipeline is created with non-rebased branch, some of the
> > stage-2 jobs will be stuck - so the pipeline won't complete.
> > Satish
