[petsc-dev] is make alldoc tested?
    Smith, Barry F.
    bsmith at mcs.anl.gov
    Tue Feb  4 14:47:44 CST 2020
  We should still be doing the testing now
> On Feb 4, 2020, at 2:46 PM, Jed Brown <jed at jedbrown.org> wrote:
> Moving toward Sphinx (as Patrick has been working on) will help reduce
> the number of stages and improve identification and reporting of
> diagnostics/errors.
> Satish Balay via petsc-dev <petsc-dev at mcs.anl.gov> writes:
>> Don't know how we'll monitor scheduled tests. Unless there is an error in CI - issues that come up will be ignored as before.
>> perhaps we can add a smaller (subset of) doc build in CI.
>> Currently we have 20 odd stages in doc build targets - and errors in each stage are ignored. So will have to fix them to stop on error [in the subset of targets we build in CI]
>> And all doc-only changes would have to be run through this CI test - before merge..
