[petsc-dev] is make alldoc tested?
    Jed Brown
    jed at jedbrown.org
    Tue Feb  4 14:46:47 CST 2020
Moving toward Sphinx (as Patrick has been working on) will help reduce
the number of stages and improve identification and reporting of
diagnostics/errors.
Satish Balay via petsc-dev <petsc-dev at mcs.anl.gov> writes:
> Don't know how we'll monitor scheduled tests. Unless there is an error in CI - issues that come up will be ignored as before.
> perhaps we can add a smaller (subset of) doc build in CI.
> Currently we have 20 odd stages in doc build targets - and errors in each stage are ignored. So will have to fix them to stop on error [in the subset of targets we build in CI]
> And all doc-only changes would have to be run through this CI test - before merge..
