[petsc-dev] Testing seems broken in master
Barry Smith bsmith at petsc.dev
Thu Dec 31 17:40:54 CST 2020
  I think I have it "fixed" now in the branch, once it passes the pipeline I will shepard it through the MR quickly. Sorry about this, even all our CI testing can miss a great deal.
  Barry
> On Dec 31, 2020, at 2:44 PM, Barry Smith <bsmith at petsc.dev> wrote:
>   This is a different (3rd) problem. Funny it didn't bother anyone for two months.
>   Fix is in barry/2020-12-29/fix-petscdiff-bracket but the pipeline keeps failing ts_tutorials_advection-diffusion-reaction-ex3_2 fails on different machines with slightly different counts. I don't see how this change could cause that! But gets old results on my machine. Very frustrating.
>   Barry
>> On Dec 31, 2020, at 1:02 PM, Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
>> On Thu, Dec 31, 2020 at 1:48 PM Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> wrote:
>>   So the programs output changes and should no longer match that in the output/* file yet the test harness does not error with a statement that the two outputs do not match?
>>    I noticed the gmakegentest.py is not being run before it runs the test? Does this mean it is just running all the old stuff which does match fine?
>>    Then either how petscdiff is called by the test harness has changed or petscdiff has changed and does not detect changes anymore
>>    BTW: I always use -f ./gmakefile.test test not just the gmakefile
>>    All the PETSc changes are trivial and can be seen with a simple diff, it is hard to believe they would cause this behavior but I guess they must.
>>    You can go to PETSC_ARCH/tests/snes/tests and run the ex13 shell script directly.
>> It is the sed problem:
>> master *$:/PETSc3/petsc/petsc-dev$ /PETSc3/petsc/petsc-dev/lib/petsc/bin/petscdiff   /PETSc3/petsc/petsc-dev/src/snes/tests/output/ex13_bench.out ex13_bench.tmp
>> sed: 1: "s/\033[1;31m//g": unbalanced brackets ([])
>> sed: 1: "s/\033[0;39m\033[0;49m//g": unbalanced brackets ([])
>> The error was getting eaten.
>> This is in current master. Is it fixed in a branch?
>>    Matt
>>   Barry
>>> On Dec 31, 2020, at 12:38 PM, Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
>>> I just pulled master, and simple alterations to tests do not produce a failure:
>>> master *$:/PETSc3/petsc/petsc-dev$ PETSC_ARCH=arch-master-debug make -f ./gmakefile test search="snes_tests-ex13_bench" TIMEOUT=5000 EXTRA_OPTIONS="-dm_
>>> refine 0"
>>> Using MAKEFLAGS: EXTRA_OPTIONS=-dm_refine 0 TIMEOUT=5000 search=snes_tests-ex13_bench
>>>         TEST arch-master-debug/tests/counts/snes_tests-ex13_bench.counts
>>>  ok snes_tests-ex13_bench
>>>  ok diff-snes_tests-ex13_bench
>>> I check that the runs produce different output when done manually.
>>> Scott and Barry, could this be related to changed to testing?
>>>   Thanks,
>>>      Matt
>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20201231/acd93bba/attachment.html>
