[petsc-dev] ASM for each field solve on GPUs
Mark Adams
mfadams at lbl.gov
Wed Dec 30 17:30:01 CST 2020
I see that ASM has a DM and can get subdomains from it. I have a DMForest
and I would like an ASM that has a subdomain for each field. How might I go
about doing this? (the fields are not coupled in the matrix so this would
give a block diagonal matrix, and thus exact with LU sub solvers.
I am then going to want to get these separate solves to be run in parallel
on a GPU (I'm talking with Sherry about getting SuperLU working on these
small problems). In looking at PCApply_ASM it looks like this will take
some thought. KSPSolve would need to be non-blocking, etc., or a new apply
op might be needed.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20201230/d1a7b3a7/attachment.html>
