[petsc-dev] slight inconsistency with test harness?
    Scott Kruger
    kruger at txcorp.com
    Wed Dec 30 12:23:10 CST 2020
https://gitlab.com/petsc/petsc/-/merge_requests/3525
Your complaint about the test harness verbosity when running restricted
set of tests is also fixed in this one as well (and this one is so nice
I should have done this quite awhile ago).
Scott
On 12/29/20 8:32 PM, Barry Smith wrote:
> Scott,
> I spent way to much time puzzling over why
> [bsmith at p1 petsc]$ make -f gmakefile.test test search='src*ts*tests*ex26*'
> Using MAKEFLAGS: -- search=src*ts*tests*ex26*
> # No tests run
> # No tests run
> # No tests run
> When I ran with help I noticed some seemingly slight inconsistency. It
> says for a directory you include the src but for a specific example
> you do not include src?
> Would it be possible to add support to the test harness so if one puts
> in the src* for a specific example it still works? For silly people
> like me who type the full directory path, and keeping typing it over
> and over again even though it does not work. And to support not
> putting in the src/ for directories?
> Thanks
> Barry
> Tests can be generated by searching with multiple methods
> For general searching (using config/query_test.py):
>   make -f gmakefile.test test search='sys*ex2*'
> or the shortcut using s
>   make -f gmakefile.test test s='sys*ex2*'
> You can also use the full path to a file directory
>   make -f gmakefile.test test s='src/sys/tests/'
> To search for fields from the original test definitions:
>   make -f gmakefile.test test query='requires'
> queryval='*MPI_PROCESS_SHARED_MEMORY*'
> or the shortcut using q and qv
>   make -f gmakefile.test test q='requires'
> qv='*MPI_PROCESS_SHARED_MEMORY*'
> To filter results from other searches, use searchin
>   make -f gmakefile.test test s='src/sys/tests/' searchin='*options*'
> To re-run the last tests which failed:
>   make -f gmakefile.test test test-fail='1'
> To see which targets match a given pattern (useful for doing a
> specific target):
>   make -f gmakefile.test print-test search=sys*
> To build an executable, give full path to location:
>   make -f "gmakefile.test" ${PETSC_ARCH}/tests/sys/tests/ex1
> or make the test with NO_RM=1
> Above is from: help-make help-targets help-test
> # No tests run
> # No tests run
> # No tests run
> [bsmith at p1 petsc]$ make -f gmakefile.test printtest
> make: *** No rule to make target 'printtest'.  Stop.
> [bsmith at p1 petsc]$ make -f gmakefile.test print_test
> make: *** No rule to make target 'print_test'.  Stop.
> [bsmith at p1 petsc]$ make -f gmakefile.test print-test
> [bsmith at p1 petsc]$ gmake -f gmakefile.test print-test
> [bsmith at p1 petsc]$ gmake -f gmakefile.test test
> # No tests run
> # No tests run
> # No tests run
> [bsmith at p1 petsc]$ ls src/ts/tests/ex26
> ex26   ex26.c
> ex26   ex26.c
> [bsmith at p1 petsc]$ gmake -f gmakefile.test test search='ts*tests*ex26*'
> Using MAKEFLAGS: -- search=ts*tests*ex26*
>         CC arch-ci-linux-cuda-double/tests/ts/tests/ex26.o
>   CLINKER arch-ci-linux-cuda-double/tests/ts/tests/ex26
Tech-X Corporation               kruger at txcorp.com
5621 Arapahoe Ave, Suite A       Phone: (720) 466-3196
Boulder, CO 80303                Fax:   (303) 448-7756
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20201230/122fd0ea/attachment.html>
