[petsc-dev] Documentation version mismatch?
    Satish Balay
    balay at mcs.anl.gov
    Mon Dec 28 12:18:00 CST 2020
On Sat, 26 Dec 2020, Barry Smith wrote:
>   Run release on my machine and it worked correctly. (with bibtex_bibfiles = ['../tex/petsc.bib','../tex/petscapp.bib’] patch). producing 3.14.2
>   The last run of latest (release) on readthedocs 2 days ago failed.
>   Run my branch of release now on readthedocs and it produces https://docs.petsc.org/en/barry-2020-12-26-docs-add-bibtext-release/ <https://docs.petsc.org/en/barry-2020-12-26-docs-add-bibtext-release/>  which has the 3.14.2 as it should be.
>   So the problem could be readthedocs has never properly run on latest (release) past the 3.14.0 version, hence there is not a newer version there. Or something else?
> https://gitlab.com/petsc/petsc/-/merge_requests/3513
merged the branch - and the docs are now regenerated.
Satish
>   BTW: I think the naming is all wrong for readthedocs and we'll need to fix.
>      Currently latest -> release   (readthedocs says latest should point to the development version).  I propose we change to
>      release -> release version
>      master/main -> master/main version
>      latest -> master/main version
>   Barry
> > On Dec 25, 2020, at 4:28 AM, Pierre Jolivet <pierre at joliv.et> wrote:
> > Hello,
> > https://docs.petsc.org/en/latest/ <https://docs.petsc.org/en/latest/> shows "PETSc 3.14.0 documentation” in the header and footer.
> > Shouldn’t it either display 3.14 or 3.14.2?
> > Thanks,
> > Pierre
> > <Screenshot 2020-12-13 at 12.31.24 PM.png>
